Author Topic: Til Sölu: Lincoln Electric HandyMIG K-14000 - Lækkağ Verğ  (Read 2947 times)
« on: September 24, 2007, 14:44:26 »
Lítil og nett MIG-suğa í skúrinn, nánast ónotuğ.
Features
Dimensions (mm) H x W x D : 590 x 250 x 380
Weight:18 kgs.
2 year warranty on parts and labour.
Processes MIG, Flux-Cored
• Suitable for the welding of most thin sheet steel applications
• Connects to 230V, 16 amp outlet
• Safe operation - no electrical current until trigger is pressed
• Compact, portable, lightweight and easy to use
• Ideal for general light maintenance projects
• Continuous wire feed speed adjustment and four selectable voltage steps for precise control
• Fan-cooled for long life expectancy
• Supplied ready to weld
• MIG and Flux Cored Applications
Welder Specifications
Primary Input 230VAC
Output 45-80A
Rated CV Output Amps/Duty Cycle 70A/20%
Wire Feeder Specifications
Wire Feed Speed Range - m/min 0-9.0
Solid Wire Size Range (mm) 0.6
Cored Wire Size Range (mm)0.9
Kostar nı 39.900 kr.- hjá SINDRA
Fæst á 25.000 kr-
Uppl. í síma 845-3339
