Author Topic: Til Sölu Hátalarar og MP3 magasín  (Read 3285 times)
Offline Capri 5.0
« on: September 09, 2007, 01:44:32 »
Til Sölu eru JBL SVA1600 og JBL SVA Center hátalarar. Selt sem sett á 65.000.-
SVA1600
Frequency Response
50Hz – 18kHz (±2dB)
38Hz – 18kHz (–6dB)
Sensitivity
89dB @ 2.83 volts/1 meter
Recommended Maximum
Amplifier Power**
200 watts
Impedance
8 ohms nominal
Crossover Frequency
1750Hz
Dimensions (HxWxD)
35-3/4 x 11 x 13-1/2 inches
908 x 279 x 343mm
Weight
60 lbs/27 kg
Keypt nýtt í Sjónvarpsmiđstöđinni á sínum tíma, afhent í upprunalegum pakkningum.
SVA Center
Frequency Response
80Hz – 18kHz (±2dB)
45Hz – 20kHz (–6dB)
Sensitivity
88dB @ 2.83 volts/1 meter
Recommended Maximum
Amplifier Power**
150 watts
Impedance
8 ohms nominal
Crossover Frequency
2500Hz
Dimensions (HxWxD)
6-13/16 x 20 x 11-1/8 inches
173 x 508 x 283mm
Weight
25 lbs/11.4 kg
___________________________________________________________
Alpine CHA-S634 MP3 magasín, Verđ 25.000.-
Ai-NET and M-Bus Compatibility* (*Requires KCA-130B adaptor for M-Bus Application)
80-Disc Title Memory
CD Text Ready
M DAC
High Speed, Anti-Vibration Mechanism with Silicon Oil Dampers
Free Angle Adjustable Mounting (0° – 90°)
Additional KAE-116C Changer Magazine Available
Touch Control Ready
Dimensions 255mm x 163,3mm x 63mm
Auka diska slíđur fylgir
Keypt nýtt í Nesradio, afhent í upprunalegum pakkningum.
Áhugasamir sendiđ e-mail á endalaust@hotmail.com eđa EP.
Ingi Vöggsson
