Author Topic: Fuel cell og bensíndćla til sölu  (Read 2684 times)
Offline Dohc
  • Teitur Yngvi
    • http://www.picturetrail.com/teitury
« on: June 01, 2007, 21:17:19 »
Er međ bensíndćlu og fuel cell til sölu:
Bensíndćlan
Free Flow Rate:                  43 gph
Maximum Pressure (psi):         85 psi
Inlet Size:                             3/8 in.
Inlet Quantity:                        Single
Inlet Attachment:                    Hose barb
Outlet Size:                             5/16 in.
Outlet Quantity:                       Single
Outlet Attachment:                  Hose barb
Fuel delivery from a name you can trust.
Multi-port EFI systems require a stable fuel supply to maintain the best performance throughout the engine's rpm range. These MSD high-pressure and high-flow fuel pumps feature a roller vane pump mechanism, which is extremely resistant to clogging and jamming. The pumps mount in-line (out of the tank) with two supplied cushioned clamps for a quick and sturdy installation. The nipple inlet is 3/8 in. with a 5/16 in. outlet. The wire terminals feature brass studs for secure connections. Made in the U.S.A., these MSD pumps are ideal as "boosters" for nitrous oxide applications, or as stand-alone pumps for multi-port EFI systems on engines up to approximately 500 HP.
Fuel Cell, Aluminum, Natural, 15 Gallons, 0-90 Ohm Sender, Each
Capacity:                        15 gallons
Fuel Cell Color:                Natural
Fuel Cell Material:            Aluminum
Foam:                             Yes
Sending Unit Included:      Yes
Sender Ohm Range:         0 ohms empty, 90 ohms full ohms
Length (in):                      20.000 in.
Width (in):                       18.000 in.
Height (in):                      10.000 in.
Outlet Fitting Quantity:      Two
Outlet Fitting Size:            -8 AN
Return Fitting Size:           -8 AN
Tip Over Valve Size:         -8 AN
Sump:                              Yes
Sump Depth (in):          2 in.
Lightweight cells, heavyweight value.
Ranging in size from 1 to 20 gallons, these strong, lightweight aluminum RCI fuel cells feature fully welded construction. Several models are available with a 0-90 ohm GM fuel sending unit.
Verđ á fuelcell 38ţúsund
Verđ á bensíndćlu 17ţúsund
Hćgt er ađ ná í mig í síma 865-3729 hérna á ţrćđinum,einkaskilabođ
eđa bara í tölvupóst: teitury@hotmail.com, teitury@turbocrew.is
R-32 GTR
