Author Topic: 1985-1994 service engine ljós  (Read 3419 times)
Offline valurcaprice
« on: April 25, 2007, 23:30:45 »
Ef að service engine ljósið er kveikt hjá ykkur þá er hérna góð leið til að komast að því hvað er að með einni bréfaklemmu :D
1985-1994 Full Size GM vehicle, Service Engine Soon Diagnosis.
    People may think that if the Service Engine Soon lamp is glowing on their car, then that means that they must take their car in to a car dealership, or a mechanic to figure out what is wrong with it.  This is not true.  I will be showing you how to pull codes from the computer on your car, yourself!
The first thing you need to do, is to find the ALCL link (otherwise known as The Assembly Line Communications Link).  On 1985, through 1991 GM cars, this is usually located just below the area where your radio is.  It's inset from the black, sound insulation panel (above where your feet are in your car).  On newer vehicles (older than 1994 though) you most likely find the connector right below the steering column!
This is what the connector looks like:  Below the connector, are descriptions of what each port is used for.
A- Ground
B- Diagnostic Terminal
C- A.I.R. (if used)
D Service Engine Soon Lamp Illumination
E-Serial Data (special tool required)
F- TCC (if used)
G-Fuel Pump
Now, to pull codes from your vehicle, you will need to make a little jumper (I use a paper clip) and connect the ports A, and B.  This will set the computer into a self-diagnostic cycle.  You will hear the fans under the hood turn on, if you are succesful.  Also, the codes that you are wanting to pull in the first place, will be flashed using the "Service Engine Soon"  lamp.
The First Code that you will see, will be a code 12.  This code is only to show you that you have sucessfuly sent the computer into its diagnostic cycle.  The Code 12 will be repeated 3 times.  after code 12 has been repeated 3 times, there will be a long pause, (approx 5 seconds) if there are any other codes, then they will be displayed.  If there are not any more codes, then the computer will flash the code 12 again
Code 12
1 flash, pause, 2 flashes
Diagnostic
This Code will flash whenever the diagnostic terminal is grounded with the ignition switch turned on and the engine is not running.
Code 13
1 flash, pause 3 flashes
Oxygen Sensor
Check the wiring and connectors from the oxygen sensor.  Replace the oxygen sensor
Code 14
1 flash, pause, 4 flashes
Coolant Sensor Circuit
(high temperature)
If the engine is experiencing overheating problems, have those fixed before continuing.  Check all wiring and connectors associated with the coolant temperature sensor.  Replace the Coolant temperature sensor.
Code 15
1 flash, pause, 5 flashes
(low temperature)
See above, then check wiring connections at the ECM
Code 16
1 flash, pause, 6 flashes
System High Voltage
If the voltage is above 17.1 volts for more than 2 seconds, the Service Engine Soon light will illuminate.  Have the charging system checked
Code 21
2 flashes, pause, 1 flash
Throttle Position Sensor
Check for a sticking, or mis-adjusted throttle position sensor
Code 22
2 flashes, pause, 2 flashes
check TPS adjustment.  Replace the TPS sensor
Code 23
2 flashes, pause, 3 flashes
Manifold Air Temperature
Check the MAT sensor, wiring, and connectors for a possible open circuit.  replace the MAT sensor
Code 24
2 flashes, pause, 4 flashes
Vehicle Speed Sensor
This code can only appear when the vehicle is in motion, if it appears when the car is not in motion, ignore it.  Check ECM connections, any other problems should be diagnosed by a qualified mechanic.
Code 25
2 flashes, pause, 5 flashes
Check the voltage between the MAT sensor and the ECM.  voltage should be above 4 volts
Code 26
2 flashes, pause, 6 flashes
Quad Driver Circuit
Have the car checked by a dealer
Code 27
2 flashes, pause, 7 flashes
Gear switch Diagnosis
Code 28
2 flashes, pause, 8 flashes
Same as code 27
Code 29
2 flashes, pause, 9 flashes
Same as code 27
Code 31
3 flashes, pause, 1 flash
Park/nuetral switch
Check all connectors, and for a faulty switch
Code 32
3 flashes, pause 2 flashes
EGR System
Check vacuum hoses and connections for leaks and restrictions.  Replace the EGR solenoid or valve
Code 33
3 flashes, pause, 3 flashes
MAF Sensor
Have the mass air flow sensor replaced
Code 34
3 flashes, pause, 4 flashes
MAF Sensor
Check for loose or damaged air duct, misadjusted minimum idle speed and cacuum leaks.  Inspect the MAF sensor
and the electrical connections
Code 38
3 flashes, pause, 8 flashes
Brake Input Circuit
Check brake light switch connections, adjust OR replace switch
Code 39
3 flashes, pause, 9 flashes
Torque Converter Clutch
Check ECM connections, check for faulty Torque Conver Clutch solenoid
Code 41
Cam Sensor
Check for faulty connections, or a faulty cam sensor.  Maybe also indicate a problem with the vehicle's timing chain.
Code 42
4 flashes, pause, 2 flashes
Electronic Spark Timing
check for faulty connections, or a faulty ignition module
Code 43
4 flashes, pause, 3 flashes
Electronic Spark Control
Check for a faulty knock sensor, or Mem-Cal
Code 44
4 flashes, pause, 4 flashes
Lean Exhaust
Check the ECM wiring connections.  Check for vacuum leaks at the hoses and intake manifold gasket
Code 45
4 flashes, pause, 5 flashes
Rich Exhaust
Check the evaporative charcoal canister and its components for the presence of fuel
Code 46
4 flashes, pause, 6 flashes
Power Steering pressure switch
Check for faulty connections, or a faulty switch
Code 48
4 flashes, pause 8 flashes
Misfire Diagnosis
Check the ignition and fuel systems
Code 51
5 flashes, pause, 1 flash
Prom or Mem-Cal
Make sure the MEM-Cal or prom is properly installed in the ECM.  Replace Mem-Cal or prom
Code 52
5 flashes, pause, 2 flashes
Cal-Pak
Check the Cal-Pak to insure properation.  replace the Cal-Pak
Code 55
5 flashes, pause, 5 flashes
ECM
Check for faulty connections.  Replace the ECM
Code 63
6 flashes, pause, 3 flashes
EGR Flow Check
Have vehicle serviced by a dealer
Code 64
6 flashes, pause, 4 flashes
Same as Code 63
Code 65
6 flashes, pause, 5 flashes
Same as Code 63
Valur kristinsson
Jeep Cherokee - 1993 - seldur
Audi 100 - 1990 - TIL SÖLU
Caprice classic - 1989 TIL SÖLU
« Reply #1 on: April 26, 2007, 00:37:05 »
Kallast að flassa kóðann er frá  86-93 í Camaro/Pontiac líka
Offline camaroz28
« Reply #2 on: April 26, 2007, 02:26:40 »
á þetta ljós bara ekki að vera í öllum amerísku :lol:
« Reply #3 on: April 26, 2007, 13:23:35 »
bíst nú við að þetta ljós sé í flestum amerískum og fleiri bílum, þíðir samt ekki að þessi aðferð virki líka í þeim bílum. :roll:
Valur kristinsson
