Author Topic: /// HKS SSQV(Universal Blow off Valve) \\\Fæst á 30 þús !!!  (Read 2730 times)
Offline SupraTT
Til sölu Nýr ónotaður HKS SSQV og BOV aluminum Flange til að sjóða á intercooler pipe
The HKS Super Sequential Blowoff Valve (SSQV) is a dual stage pull-type relief valve. Unlike typical push type blow-off valves, the HKS Super Sequential Blowoff Valve (SSQV) will not leak under any level of boost because the boost pressure in chamber "C" keeps the valve closed against its seat. The Super Sequential Blowoff Valve (SSQV) releases excess boost when there is a pressure alteration in its chambers, not by the rate of boost pressure or vacuum in the line.
This ensures a quick valve response and complete closure during idle. Many competitors use a push-type blow-off valve design with a large valve to accommodate high boost / high horsepower applications. These large valves react slowly and require high pressure to open, and are not able to activate and prevent compressor surge at light-load conditions. On the other hand, smaller, fast reacting push-type valves do not discharge the airflow capacity required for high horsepower applications and tend to slowly open and leak as boost pressure overpowers the spring. For maximum performance, the HKS Super Sequential Blowoff Valve (SSQV) incorporates both a small primary valve for ultra quick activation, and a larger secondary valve for additional discharge capacity. The HKS Super Sequential Blowoff Valve (SSQV) is engineered to initially open the small primary valve at light throttle and load conditions, then sequentially opens the secondary valve for additional relief capacity under high boost and load conditions. The HKS Super Sequential Blowoff Valve (SSQV) is constructed of polished billet aluminum, which ensures long-term durability and a high luster look. The mounting base utilizes a circular mounting flange that combines with a C-clip snap ring and O-ring gasket to insure an excellent seal. The triple-fin discharge port design produces a powerful, unique and aggressive blow-off sound.
Expect a "whooshing" air sound followed by a high-pitched whistle with this BOV.
Getið addað mér á msn ragnare_18@hotmail.com
Sími: 8699237
Suzuki Hayabusa // 9.78@139mph // 1.42 60ft
Suzuki GSX-R 1000 K7 10.00@147.5mph //Annað sæti KOTS 2012
9.42@147mph Án nitro // 1.52 60ft Mesti endahraði 149mph
9.28@151.5mph með Nitro // 1.58 60ft Mesti endahraði 153.6mph
CBR 954 10.6@135mph // Selt
