Author Topic: C16 eða eitthvað líkt ?  (Read 3969 times)
Offline SupraTT
« on: September 04, 2006, 01:07:02 »
Blessaðir
Hvar er hægt að redda sér C16 eða eitthverju race bensíni ?
var að kaupa dálítið að dóti í bílinn og á eftir að þurfa svolítið öflugara bensín þegar það er skrúfað upp í þessu  :wink:
takk
Ragnar Á Einarsson
og já þetta er það sem var keypt(en er ekki komið í bílinn )
Boost Logic Stage 3 Turbo Kit - 71mm Turbo with a .81 A/R
This kit includes:
SUS321 Tig Welded Tubular Header
HKS 50mm SS Wastegate
4” Stainless Steel 304 Downpipe
4” Stainless Steel 304 Midpipe
4” Aluminum Intake Pipe with Anti-Heat Coating
2 1/2" Aluminum Intercooler Pipe with Anti-Heat Coating
Braided Oil feed and Return Kit with Aeroquip fittings and Lines
4" K&N Filter
K&N Breathers
High Quality Silicone Connecters
ABS Heat Shield
Clamps and Miscellaneous items
Installation Instructions
Capable of more then 700+rwhp
Powerhouse Racing Stage 2 Complete Fuel System
Includes dual Walbro fuel pumps, PHR 17.5mm ID high flow fuel rail upgrade, Siemens 850cc fuel injectors, fully assembled and pressure tested -6AN Stainless Steel braided fuel lines, PHR quick-release injector clips, liquid-filled fuel pressure gauge, Aeromotive EFI fuel pressure regulator, polymer fuel pump wrap, and all necessary hardware for a complete installation.
This dual fuel pump setup has been tested to over 850 Rear Wheel Horsepower with no loss of fuel pressure.
AEM EMS (Engine Management System)
AEM Map Sensor - 3.5 bar
This AEM 3.5 bar Map sensor will allow accurate control of boost up to 35psi.
GM Intake Air Temp Sensor for use with AEM EMS
GM Intake Air Temp Sensor Connector for use with AEM EMS
Greddy 3-Row Front Mount Intercooler Kit
Crower Springs and Retainers Set
HKS Camshafts - 264 Duration
HKS DLI-2 Twin Power Ignition Amplifier for Direct Ignition Engines
PLX Devices R-500 Wide Band Kit
Accurately measures Air/Fuel Ratio, EGT, and Knock
- Powerful 32 bit integrated processor, RAM, and FLASH technologies
- Integrated 6 Inputs for data logging (2 Speed, 4 Analog)
- Built-in amplifier for audible knock output to speakers or headphones
- Over 80 minutes of onboard memory
- 4 analog outputs (User configurable)
- Fully customizable LED warning light or shift light
- High speed USB 2.0 interface
- Large dot matrix display with blue backlight
- 100% backwards compatible with M-Series controllers
- Compact dash mountable design (4.75 x 2.25 x 1 inch)
- Sensor soft start circuitry, prolongs o2 sensor life
- Powerful PC analysis software included (PLX Logger Version 2.0+ Free Download)
- Field firmware upgradeable (more features added to R-500 regularly)
HKS Racing Blow-Off Valve Type 2 This BOV is rated to hold 800rwhp
HKS EVC 5 - KPA Measurement (Electronic Boostcontroller)
Boost Logic Crank Pulley
NGK Model 3330 Spark Plug
Suzuki Hayabusa // 9.78@139mph // 1.42 60ft
Suzuki GSX-R 1000 K7 10.00@147.5mph //Annað sæti KOTS 2012
9.42@147mph Án nitro // 1.52 60ft Mesti endahraði 149mph
9.28@151.5mph með Nitro // 1.58 60ft Mesti endahraði 153.6mph
CBR 954 10.6@135mph // Selt
Offline Alpina
    • http://www.solpallar.com
« Reply #1 on: September 04, 2006, 01:13:19 »
Vvvvvvváá
þetta er alvöru aukahluta listi hjá þér :shock:  :shock:
Sveinbjörn Hrafnsson
E30 CABRIO      S38B38
ALPINA BITURBO  346 @ 507
Offline Gunni gírlausi
bensínnnnn
« Reply #2 on: September 04, 2006, 09:50:46 »
Notaðu bara 100oktan avgas eins og ég  :wink: það kostar um 145-150 kr L.
Þú ert með forritanlega vélstjórnunar tölvu og ættir því að geta notað hvaða bensín sem er, stillir bara búst og kveikju eftir því sem bensínið ræður við.
Gunni
60ft............1.924
mid mph......93.75
660............8.006
mph...........115.68
ET..............12.287
Hoosier daddy....
VW Golf GTi-16VT
Offline SupraTT
Re: bensínnnnn
« Reply #3 on: September 04, 2006, 12:13:16 »
Quote from: "Turbeinn"
Gunni
Ég var svona meira að hugsa um að vera með eitt map á 98 okt og blása bara u.þ.b 16-18 psi ..............síðan annað map sem þyrfti svolítið öflugara bensín en 100 okt t.d 114+oktan því þá væri maður kannski að blása nálægt 30 psi
Offline gstuning
Re: bensínnnnn
« Reply #4 on: September 04, 2006, 14:33:15 »
Quote from: "SupraTT"
Gunni
Það sem þú vilt fyrst gera er að fá dótið til að virka hjá þér
svo skaltu pæla í bensíni,
Það er engin ástæða til að fara plana hvaða bensín þú ætlar að nota,
Listinn hjá þér er allsvakalega heavy duty og fitta honum í bílinn er mál #1
With great challenges comes great engineering.
Gunnar Reynisson -Dyno Dynamics-
Dyno Time 34h |
Offline SupraTT
Re: bensínnnnn
« Reply #5 on: September 04, 2006, 19:16:31 »
Quote from: "gstuning"
Gunni
jamm veit það  :wink:  en ætlaði bara vera viss hvar maður fengi þetta þegar það kæmi að því að fara Tjúna
Offline ElliOfur
    • http://www.123.is/elliofur/
Re: bensínnnnn
« Reply #6 on: September 04, 2006, 21:48:39 »
Gunni
Hvar færðu þetta bensín? Er þetta ekki venjulega flugvélabensínið bara?
kveðja, Elmar Snorrason
_________________
http://www.123.is/elliofur/ - heilmikið bílagrúsk
« Reply #7 on: September 04, 2006, 23:06:55 »
Flugvélabensín og bæta smá Toluene(Tólín) útí en það er betra að byrja á 98 og fikra sig áfram
