Author Topic: corvette álhedd castings#113  (Read 3531 times)
Offline stigurh
« on: March 30, 2006, 09:21:07 »
Pocketportuð Corvette álhedd casting #113
Flott hedd með ventlum.
Passar á flestar chevy vélar og allar þær gömlu
Þetta eru bestu chevy heddin sem komu frá GM í corvette sbc
The Corvette cylinder head’s advanced design features include D-shaped exhaust ports that enhance the flow of burned gases, high-velocity intake runners that provide crisp throttle response, and centrally located spark plugs that improve combustion efficiency. Valve seat inserts for 1.94” diameter intake valves and 1.50” exhausts are installed in the 58cc combustion chambers. Raised rocker cover rails with machined sealing surfaces virtually eliminate rocker cover gasket oil leaks. A pair of aluminum cylinder heads offers a weight savings of approximately 50 pounds over comparable cast iron cylinder heads. (A bare aluminum casting, less valves and springs, weighs 19 pounds, versus 44 pounds for a bare cast iron head). This reduction in total engine weight of 50 pounds can improve handling, acceleration, and fuel economy.
Sem sagt gott dót.
Aðeins 45000 fyrir góð hedd í vorhreingerningunni.
stigurh 8926764
