Author Topic: T/S : Painless Universal 18-Circuit Harnesses  (Read 2210 times)
Offline Trans Am '85
« on: April 13, 2005, 17:51:27 »
Selst á 25.þús kr. Ónotað og ennþá í kassanum. Hafið samband í einkapóst hérna eða í síma : 6613384 , Bjössi
Brand:   Painless Wiring
Product Line:   Painless Performance Universal 18-Circuit Harnesses
Circuit Quantity:   18
Ignition Key Location:   Dash
Harness Length:   Standard
Fuse Block Included:   Yes
Fuse Block Location:   Front
Fuse Style:   Spade
Painless wiring for additional electrical accessories.
Wiring Harness, Universal, 18-Circuit, Dash Ignition, Front Mount Fuse Block, Spade Fuse, Kit
Painless Performance universal 18-circuit harnesses come ready to install and allow you to add other accessories to the basic wiring. They include following: air conditioning/heat, brake lights, coil, horn, electric fan, emergency flashers, gauges/dash instruments, headlights, radio (constant and ignition hot), turn signals, wipers, dome lights, third brake light, and tail lights. They add circuits for power door locks, power windows, accessory plug, electric fuel pump, backup lights/cruise control, electric choke, and power antenna. Choose from the following styles:
Column mounted includes GM (column mounted) ignition switch plugs and a GM (column mounted) turn signal switch plug pre-terminated and ready to install. Also has pre-wired plugs for headlights and the dimmer switch.
Dash mounted does not include the GM column mounted ignition switch plugs but includes the GM column mounted turn signal switch plugs and terminal.
Björn Eyjólfsson
