Author Topic: Ventlagormar K-Motion KMO-K-9000  (Read 2018 times)
Offline stigurh
« on: March 30, 2005, 12:44:37 »
K-Motion Valve Springs
Valve Springs, Dual, 1.550 in. Outside Diameter, Set of 16
 Today $251.95 at Summit
Outside Diameter of Outer Spring (in): 1.550
Coil Bind Height (in): 1.150
Damper Spring Included: No
Spring Rate (lbs/in): 579
Inside Diameter of Outer Spring (in): 1.100
Inside Diameter of Inner Spring (in): .717
Valve Spring Style: Standard
Coated: No
Quantity: Sold as a set of 16.
Coiled from the finest materials.
Why are these K-Motion Valve springs the choice of so many winning circle track and drag racers? K-Motion springs are coiled from the finest chrome silicon or H-11 tool steel and then heat treated and or stress relieved to the correct Rockwell hardness for each application. The springs are then visually checked for tool marks or pits and dampers are radius ground and de-pointed for longer life. Each spring is pressure checked and boxed with no more than five pounds variation per box.
251.95*61,6 = 15520kr
Pantaði 2 gorma og fékk tvö sett  !!!
Gerðu góð kaup.
Harrý Samúel 8614622
