Author Topic: Hvernig taka skal burnout!  (Read 4415 times)
Offline 440sixpack
« on: March 14, 2005, 21:30:17 »
-Helmet on/fasten seat belt
-start engine/check gauges
-Drive around the water, back into the water box then roll forward slightly out of water
-lock the front brakes (foot or line lock)
- do not start your burnout until directed to do so by track personell
-Burnout with manual valve body: Start in second gear, hit the gas *HARD* to keep the car straight. Shift into high gear as soon as possible, hold rpms around 5 grand in the water box for at least 5 seconds (or until the engine slows down from the tires beginning to grip)
-Pull out of the water box under power, either at the same throttle position or at WOT (your choice--it's worth exp[erimenting with).Pull out only a couple feet.
-Let off the gas and hit the brakes *hard* asap to avoid going over the starting line
-Put trans in neutral
-Check gauges/Clear out the motor if you want
-Put trans in low gear
-if you want to do a dry hop, do it now (I don't)
-making sure the car is pointed dead straight, ease up to the starting line slowly until the pre-stage bulb comes on.
-Stop.
-Move forward very slowly until the Stage light comes on
-Stop. You are now "shallow staged".
-If you want to leave on the converter, get your rpms up right now and keep them there. (My car likes to leave off idle, so I don't do this).
-From this point until the beginning of the run, *do not take your eyes off the tree*
-Leave on the last yellow
If followed closely, this procedure greatly reduces the chance of making a fool of oneself the first time at the track!
Þórður Ingvarsson
1970 Dodge Challenger R/T 440 shaker.(seldur) (O O [====R/T=] O O)
1971 Plymouth Cuda Pro-street Project.  (O O {]{]{]|[}[}[} O O)
2003 Mercedes Benz E-500 Avantgarde
2007 Yamaha YZF R-1
Offline Anger
« Reply #1 on: March 14, 2005, 21:57:07 »
hver ætlar að íslenska
« Reply #2 on: March 14, 2005, 23:22:40 »
vantar inn: dont hit track staff while perform a burnout!
Offline Jón Þór Bjarnason
« Reply #3 on: March 15, 2005, 14:54:27 »
S:899-3819
2006 VW Passat 2.0L HighLine
Re: Hvernig taka skal burnout!
« Reply #4 on: March 15, 2005, 16:12:09 »
Quote from: "440sixpack"
quote]
Allt gott og blessað með allt nema þetta, hef heyrt frá dekkjaframleiðendum, að við það að gera "dry hop" þá eyðiru fylmu (klísturs fylma) á dekkinu sem þú bjóst til í burnoutinu...
Offline 440sixpack
« Reply #5 on: March 15, 2005, 22:25:18 »
Enda stendur " (I don't) "
Þórður Ingvarsson
2007 Yamaha YZF R-1
